Deletes internal resources for one or all static LSPs.
| lsp_name | Identifies the LSP to be deleted. |
| all | Specifies that all LSPs are to be deleted. |
N/A.
All resources associated with the specified LSPs are released. Static LSPs cannot be deleted when the LSP is configured for an IP route or VPLS configuration.
The following command deletes a static LSP:
delete mpls static lsp lsp598
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
